Hi Jeroen,
The KFLOP LVTTL I/Os are 3.3V signals diode clamped to the 3.3V power rail. They should not be driven above 3.8V or may be damaged. Most +5V TTL outputs do not do this as they are only required to drive 2.8V or higher. The KFLOP inputs marked 5V Tolerant have series 47ohm resistors to prevent damage if driven to 5V. But this should be avoided.
If you wish to use a switch to drive the inputs high they may be switched to 3.3V. Of course opening a switch will not guarantee that the inputs go low as they may still float high. A pull down resistor should be used to guarantee the input goes low. The first 8 inputs on KFLOP JP4 and JP6 have 150ohm pull down resistors that may be useful for this purpose.
The I/O should not be configured as an output and at the same time driven externally. The output drive is internally limited to ~16ma so it usually doesn't cause damage, but regardless you should never do this.
Message: 12335 |
Date: 10/2/2015 |
Subject: Re: connecting limit switches |
Thanks Tom, this info cleared up things for me. I will add some pull-down resistance to the limit switches and will use 3.3 volts. Best regards, Jeroen
